curving curtain wall
How can I do this? Its a curtain wall that curves into a "curtain roof"
7 REPLIES 7
Dwight
I went thru the library but can't find an object to suit.
Four Seasons Greenhouses has a special flavor of ArchiCAD with those shapes as object, but they don't seem to be in the real library. Double check before doing this:
You can construct the straight sloped parts using roof elements.
The bent nose piece could be from segmented roof parts using the roof arc tool to get the bend- see attached for tool location.
You'll set the magic wand to a high number to keep the roof segments tiny and the nosing smooth. Once you have the segments for the glass, copy them and simply increase the roof thickness to make the flanking mullions.
For muntins, make short roofs with perpendicular sides.
This exercise relies on cut and paste - use the section view to evaluate and position the pieces as you work.
For the nosing, you could also make a curved wall and save it as a library object, but I suspect you are not performing at that level yet - and for a one-off, why bother?
Dwight Atkinson
There are several "green house" objects on Objects on Line.
I would try TrussMaker for the vertical frames,
profiler for the horizontal mullions,
make the glass panels with roofs and walls,
and the curved glass with Profiler.
Remember TrussMaker works of center lines.
Peter Devlin
I cant seem to find the four seasons greenhouses youre talking about...do you happen to have a site or something?
Dwight
buy the object at objects online if you aren't inclined to make it as was described.
Dwight Atkinson
"ArchiGreenhouse" at Objects on line
Aussie John
You could use the profile manager for all the horizontal elements and then just add the vertical mullions as separate identities
Cheers John
[/size]
Dwight
You win: "Best solution with new-not-yet-coming-to-the-average-mind feature" category!
Dwight Atkinson
