Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
custom made curtain wall panel doesn't appear in the panels menu
I saved a certain shape as a curtain wall panel, but when I go to the curtain wall menu, and want to select this custom-made panel, it doesn't appear among other types of panels in panels menu.
It seems as only built in library objects are shown, and not objects from embedded library as well.
Does anyone know what might be going on here?
Thank you!
So you definitely 'Save Selection as Library part > Curtain Wall Panel' ?
It is working fine for me.
Thank you Barry!
Your screenshots helped me to realize that I didn't select 'CW custom panel 22' as a type.
It works now 😃
