custom profiles
Hi, I am trying to use the custom profile-profile editor, and the composite wall which is stud with skin either side shows up as a solid line as shown, how do I change the graphics to show the skins? any advice appreciated.
Bruce
Could be a couple of different things:
- check to see if you have line weights turned on in your display - if on they may just be showing too thick
- check to see you're using coloured pens, not just black
- check to see the fills you're using are different
It's a bit hard to tell from the image, but those are the things I'd be checking first
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
