cut floor plan vs morphs
Claudio Lima
hi all !
I'm importing an STRUCTURE IFC as morphs, and the problem is :
the slab, the is below 0.00 floor , so it does not appear on the floor plan.
all the tests I made, I can make what I want but, not for IFC hotlink... ie, if the morph is set to ONW STORY ONLY, it works.
but, hotlinking the IFC, it doesn't allow me that option
any help ? idea ?
tnks
regards
claudio
since ARCHICAD 3.42 to ARCHICAD 26
8 REPLIES 8
mija
My practice is that I first import ifc in individual archicad where I adjust all the stories, then I hotlink it to the file.
Archicad 26, build 3001
Montenegro
hi mija !
tnks, but that's not the problem...., see the attach image, to see what im talking about
mija
Did you try relinking them to the story you want to see them?
Montenegro
hello myja !
watch the video attached...
https://www.dropbox.com/s/gxshg1kaker1251/morph%20below%20zero.mov?dl=0
regards
c
You tried to change the cutting level from floor plan cut plan dialogue by setting show down to the lower floor to GF by 0.10m, It works for me.
AC 28 INT 5200/WIN 11
hi mahmoud !
please send me an image of that setting
Check this from Archicad help,
https://help.graphisoft.com/AC/26/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC26_Help%2F050_Views...
this I already know...., I was wondering why your file, was ok
