cut plane zoom
hi how I can zoom cut plan window I cant see any thing ?
thank you
Dwight
Placing a cutting plane with precision can be tricky.
1: Select [not marquee] the elements key to the placement of the cutting plane, make a 3D view of these elements and THEN open the Cutting Plane window gives a closer view.
2: Placing small free-floating elements outside the model will provide cutting plane reference points. Once the plane is placed, they can be deleted.
3: The Cutting Plane dialog window CAN be stretched to make the windows bigger.
Dwight Atkinson
You can set the Y, X or Z values for the cutting plane, press x, y or z before entering the value. It´s really easy to set with precision the cutting planes. Hope it helps.
