2011-05-13
02:03 PM
2023-05-26
02:32 PM
Rubia Torres
2011-05-13 05:26 PM
khashayar wrote:Why are you still running build 3004 and not the latest (bug-fixing) hotfix? 100's of bugs have been fixed since 3004...
I run Windows 7 Ultimate, 64-bit, Archicad 14, 3004 INT FULL for Teamwork.
2011-05-13 05:31 PM
Karl wrote:thank you Karl for your response.
And, it sounds like you have not been making any normal / external backups?
If the corrupt file is your only file, it is possible that Graphisoft tech support can do some data recovery magic on the file. With no other backups, that is probably your only option.
