We value your input!
differing story levels in one object-HELP
Hi, guys, I'm modeling a building that has different story levels in some parts. Problem is 2d plane. I set 0 level plane that is corresponding to one corpus and in another relative 0 plane is let's say 2 m below (it's on slope and so on). However, on a 2d plan I would like to see everything that's market as ground floor, but openings are not shown. I did try to play with story levels, and floor plan cut settings, but I can't find the appropriate solution. Is there any way to set story levels separably for each part of a building, so that it shows everything, and that 3d model remains unchanged? I hope u understand what I am asking, sorry for the bad english 😉
Make the walls show as "Symbollic cut" in Floor Plan Display setting, and doors and windows will always show as if they are cut by the Floor Plan Cut Plane.
thanks!!!
