2007-03-2712:05 PM - last edited on 2023-05-2612:22 PM by Rubia Torres
hello there!
i have a problem. i have built a story with some walls doors windows and furniture and i decided to change the elevation of all these things
everything works fine except the walls. the walls became with my outline uncut pen and the doors and windows disappeared. what can i do?
how does archicad decide above what height is uncut or cut in the floor plan?
i hope you understand
(top menu)Document/ Floor cut plane is the default setting... but then if you already have view sets defined in your navigator, you have to go and define the floor cut plane for each one within their settings (i think)
hope this helps
