disappearing palettes
I have just installed AC 11 on a new iMac. I loaded my profile info from another machine. I cannot get the coordinate info palette to show, even though it is turned on. I tried turning it off and back on but it does not show (this worked with the toolbox). Any ideas?
TIA
David Larrew
Try setting your display resolution to a higher setting. The Palette may be just out of your visible screen area.
David Larrew, AIA, GDLA, GSRC
Architectural Technology Specialist
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Thomas Holm
If David's tip doesn't work, you can open your work environment profile and set the Palette Scheme back to one of the standard locked ones.
