2005-10-10 04:47 PM
2005-10-10 05:04 PM
mdjohnson11 wrote:You're using the age-old work around for this known issue and No, there is currently not a better way.
...is there a way to have a wall show up on more than one story? ... there has to be a better way to do this.
2005-10-10 05:14 PM
mdjohnson11 wrote:Is your curtain wall a window or an object?
is there a way to have a wall show up on more than one story? on a lot of objects you can choose to have them shown on story above, story below, all stories, etc., but not for walls. i am trying to show a double height space with an curtainwall exterior. the curtainwall should be one wall instead of half on the first floor and half on the second floor. that way i just have to edit one wall instead of two and for aligning mullions and other things. right now i'm putting the full double height wall on the first story, making the wall 28' tall. i the copy and paste it onto the second floor and adjust the z value. so it is pretty much two walls occupying the same space, just showing up on two different stories. there has to be a better way to do this.
2005-10-10 05:14 PM
