don't want drawings to clone
I'm wanting to move drawings around in the folders (change the order in which they display)in the view map, but I'm not able to rearrange them. It seems to clone the drawing instead.
Is it possible to turn the cloning off?
1 REPLY 1
No, if you created a folder in the View Map by cloning, the given folder will always duplicate all items within its corresponding Project Map folder.
You should simply create a folder in the View Map and drag item into from the Project Map. The Organizer Palette can be used for that purpose as it can display 2 maps (e.g. Project Map on the left pane, View Map on the right).
