Slap, slap (or is that slab, slab
If you have walls that continue from one floor level through to the next then you can turn on the option for "show on stories" to "show on all relevant floors" in the wall settings.
This can be combined with the "Floor plan cut plane" and changing the "Floor plan display" from "Symbolic" to "Projected with ovehead" if you want an exact height for the cutting plane.
But be aware this may affect how doors and windows are displayed (they also have their own settings).
Generally you shouldn't need to worry about "projected with overhead" if you just set them to show on all relevent stories.
