Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
2014-01-1705:37 AM - last edited on 2023-05-2409:04 AM by Rubia Torres
I want to edit the shape of a curtain wall. Looking form the elevation view, I need to make a side of the curtain wall diagnol(tilted, instead of perpendicular) . I can do this in the wall command but I haven't figured out how this is done in the curtain wall.
One way is to edit the boundary is using a Fill, in the Help files see: Virtual Building > Construction Elements > Curtain Wall: A System Tool > Edit Curtain Wall Boundary in Section.
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
