editing opening in a canted wall
i am trying to move the open in the canted wall, is thier another way to modify the open location without using the array values tool??????????????????????
5 Replies 5
TomWaltz
Maybe a better explanation of what you're trying to do?
You seem to be asking about moving an opening and for some reason you are using array values (do you mean Multiply? Or are you talking about something else?)
We cannot read your mind or see your screen, so a longer explanation can help a lot
Tom Waltz
i created a canted wall with a open , i am trying to find the best way to move the opening more to the left?????????????check out the picture below
TomWaltz
The Drag command should let you move the opening (I assume that's what you mean by "open"?)
Tom Waltz
you cannot drag a opening in a canted wall?????
TomWaltz
Sure you can. In Plan, Elevation, Section, or 3D windows.
Tom Waltz
