editing with maxonForm
there is submenu in service menu - "edit selected elements with MaxonForm" but it's not active. how to activaite it. thanks.
7 REPLIES 7
Djordje
Select something that is a 3D element.
Of course, MaxonForm has to be installed previously - but it obviously is, as the menu appears
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
thank u friend.
Djordje
urusumee wrote:
thank u friend.
Welcome
Also, take a look here: http://www.graphisoft.com/support/maxonform/
Djordje
HP Omen
everything worked by your advice, but the soft was reinstalled and now after selecting object and sending it to maxon the "brows for maxonform" box is appears. is any cure for that? thanks.
Djordje
Show the Maxon folder ...
Djordje
HP Omen
thank for your existence and for help to such ignoramus.
the best quote on this forum, EVER..
