exploding PDF into editable linework
Does the ability to explode a PDF into editable elements only work if the PDF is a vector based file? If so how can you explode a raster based file?
Thanks.
2 Replies 2
Eduardo Rolon
Yes to the first one.
AC cannot vectorize the Raster PDF since it does not have any vector info.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
doober922,
It is unlikely that you would have any precision from vectorizing a raster (image) file - but it could be good enough for some preliminary design, or for building 'good enough' models of adjacent structures.
Adobe Illustrator can convert crisp linework / clipart to vector format. Here are some old discussions:
http://archicad-talk.graphisoft.com/viewtopic.php?t=36327
http://archicad-talk.graphisoft.com/viewtopic.php?t=8337
http://archicad-talk.graphisoft.com/viewtopic.php?t=31950
