export from archicad to autocad with the same length?
Hi
when i export from archicad to autocad how can export it with the same exact length
second : when i import autocad drawing how i can import it with ability to select line by line not as figure and with the same length ?
please help
3 Replies 3
NCornia
Ahmed,
Watch these recorded webinar videos hosted by Graphisoft US.
You will be asked for a subscription number or may attend as a guest.
Exporting DWG files from ArchiCAD - Understanding Your Translator Export Options https://www1.gotomeeting.com/register/780723457
Importing DWG files into ArchiCAD – Understanding your DWG Translator Import Options https://www1.gotomeeting.com/register/805769313
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Thomas Holm
ahmed_hassan wrote:
Hi
please help
Hi Ahmed,
1 In the DWG Translator settings in Archicad, you have to set what length the Drawing Unit in the DWG matches. Up here, it's usually 1 meter or 1 millimeter, but it depends on what the Autocad user wants.
2 In the Open Options of the DWG Translator settings, select Translate AutoCAD Blocks as: 2D Elements or Grouped 2D Elements.
NCornia,
i owe you for your continuous help for me thank you very much
Thomas
Thanks for confirm on this point
Best regards
