extending composites
Hey everyone,
somewhere i saw a video explaining how to adjust skins in composites so they can overlap other elements. like if i had rigid insulation skin on the outside of a composite wall and i wanted that skin to hang down from the bottom of the wall so it would overlap the floor framing. can someone point me to a tutorial or something?
wb
4 REPLIES 4
You might be thinking of extended skins in (complex) profiled walls, vs composites. But, if you're thinking of composites, then you'd need to use solid element ops.
See:
http://www.archicadwiki.com/WallSlabIntersections
http://www.archicadwiki.com/ModelingRelatedWallsAndSlabs
http://www.archicadwiki.com/CompositeWallsWithVaryingSkinHeights
ah, i don't know. my concern is that i get accurate results with the energy evaluation. i need the appropriate material characteristics throughout. will complex profiles behave the same way in the energy evaluation?
wb
wb
Unfortunately, no. The energy calc ignores the skins of a profiled wall.... So doing tricks with composites ...as in the linked articles ... will have to be the route you take.
thanks, i'll give it a go.
wb
