gradient fills
using gradient fills in ac10:
when printing small gradient fills the gradient disappears
large gardients print ok. but the narrow ones do not create enough "fountain steps" and they print flat
tried on 2 different printers and pdf output and the result was the same.
is there any solution???
11 REPLIES 11
no answer?
can u send an example?
may be you forgot to adjust the transition center of the fill pattern.
is it like this?
NO
it looks ok on screen but it prints without gradient
flat.
i cannot send example because it looks ok...
Djordje
How small?
If it is a general printing problem, it should show even in PDF.
Otherwise, update your printer's driver or check the settings of the same.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
by small i mean like 1/2 cm wide.
and it prints flat also in pdf. so it's not a printer driver problem
it's a archicad otput to printer problem.
Seiss Wagner
ZUCOC -
Attach a PDF file of the offending fill.
ArchiCad 21 / OS X 10.13.5 /
iMac 3.2GHz i5 - 32GB /AMD Radeon R9 M390 - 2048 MB/
Dual 5K - 27" Displays
here it is
the pdf otput
and the screen capture from archicad
you can easy see the difference[/img]
sorry
the image:
