ā2022-08-30 09:03 AM
ive created a 3d building and want to add hatches to the plans and sections - except when I press cover fills only transparency options come up eg 25% 50% 75% background foreground. then also when I go view, onscreen view options, there is no option to press vectorial hatches
pls help!!
ā2022-08-30 09:13 AM - edited ā2022-08-30 09:13 AM
Can you upload a picture of what you want to do and a screenshot of your settings?
ā2022-08-30 09:24 AM
What are you trying to add the cover fill to - what did you create the 3D buildings from?
The 'Vectorial Fill' is now called 'True Fill Appearance'.
ā2022-08-30 09:27 AM
this is what i currently have as a cover fill option.
this is what i want to have, so that I can add hatches to my 3d objects in plans and sections.
ā2022-08-30 09:36 AM
Have a look at your fill settings and see if all the fills you want have got the 'Cover Fill' option set.
ā2022-08-30 09:39 AM
created the building from walls and slabs and basically just need to show basic hatches like brick for walls and concrete grounds
ā2022-08-30 09:40 AM
this is what mine looks like š
ā2022-08-30 09:45 AM
Yes, that is good for the 'Foreground' fill.
That is why you can see it in the cover fill options.
Check the settings of all the other fills that you can't see as cover fills - i.e. the 'Asphalt' fill that doesn't show in the cover fill list.
ā2022-08-30 09:46 AM
how do i find these other cover fills?
ā2022-08-30 09:59 AM
Is there something wrong with your setup?
I don't have a Mac so can't compare.
But shouldn't there be those coloured dots in the fill settings window?
You should be able to see ALL fill there.
Is your Archicad version up to date with the latest build?
You didn't say what version you are using.
Also is that version compatible with you Mac OS version.
Old Archicad version may not work with new Mac OS and New Archicad version may not work with old Mac OS.
What Archicad are you using and what Mac OS?
