2010-11-28 05:20 PM - last edited on 2023-05-23 02:53 PM by Rubia Torres
2010-11-28 07:28 PM
2010-11-28 07:30 PM
Dwight wrote:im not sure i understand that, sorry...
Arched complex profile wall and SEO to extended walls gives you some outside shelter.
2010-11-28 07:47 PM
2010-11-28 08:13 PM
2010-11-28 10:43 PM
2010-11-29 06:27 PM
2010-11-29 08:14 PM
joeish wrote:Try using OBJECTiVE. Referring to the attached image:
looking to put a roof on this, not sure how or where to start, originally wanted to have a sort of corrugated metal roof.... any ideas?
2010-11-29 08:38 PM
Dwight wrote:But in English schools they still serve "Spotted D1ck"
I'm back. Went to Seattle for the Comedy Festival:
Did you know that in Oregon school cafeterias they have stopped offering fruit punch because it sounds violent?
Dwight wrote:A variation to this, as SEO's do not display correctly in the Floor Plan window, is to make the slab the shape of your roof outline, and use SEO Intersection with the CP roof. In plan you leave the slab layer visible to show your roof overhang, in 3D the slab is turned off and the roof is turned on.
When you have a Complex Profile roof and irregular walls below, make a large rectangular slab at the wall base.Use the magic wand to cut a hole in the slab that is the shape of your building.
Use the perimeter expansion feature on the pet palette to expand the hole to suit your overhang size.
Use SEO "subtract with upward…" slab as operator, roof as target.
The roof trims to match the hole.
2010-11-29 08:42 PM
2010-12-01 10:27 AM
