‎2009-11-05
11:59 AM
‎2023-05-26
12:32 PM
Rubia Torres
‎2009-11-05 05:22 PM
‎2009-11-05 06:36 PM
‎2009-11-05 07:18 PM
‎2009-11-06 03:52 AM
laszlonagy wrote:Oops
I think it is easier to understand if you show the Reference Line of the Column.
The Reference Line shows the direction from the Starting Point of the Column to the Ending Point of the Column, just as in case of Walls.
You also have the offset value of how much the Reference line is offset from the Centerline of the Column.
‎2009-11-06 06:05 AM
‎2009-11-06 03:17 PM
Barry wrote:laszlonagy wrote:Oops
You also have the offset value of how much the Reference line is offset from the Centerline of the Column.![]()
I think you mean to show the reference line of beams instead of columns.
‎2009-11-06 03:21 PM
laszlonagy wrote:you didn't confirm my last query.Barry wrote:laszlonagy wrote:Oops
Yep, I meant Beam, not Column.
‎2009-11-06 03:50 PM
‎2009-11-07 06:42 AM
