License outage
Dear Customers, We are facing with an outage in our services in Azure. You may experience issues with the Azure-based functions, like licensing, BIMcloud SaaS, Learn Portal. We are working hard on this issue to make it fixed as soon as possible. Thank you for your patience.
hotspots dominating my unlinked elevations?
Ive never had this problem before, so i assume that i recently set some of my settings incorrectly somewhere down the line. but if you look at the image you will see what i am talking about, these hotspots are doubled, and trippled up, and takes forever to delete them.
Link to pic
http://www.yourimagehost.com/is.php?i=35696&img=HotSpots.jpg
thanxs in advance
10 REPLIES 10
Stephen Dolbee
These hot spots have always occured for me. However, deleting them is fast and easy. Activate the hot spot tool, edit/select all hot spots, delete.
Steve
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
i shoulda known that one, thans steve.
keithg,
I believe these hotspots belong to objects that are scripted to have
3D hotspots. Most AC 8 and AC 9 parts have these hotspots.
It is easy to delete them. First Suspend Groups (important),
select the Hotspot tool, go to Edit menu-> Select all Hotspots,
then hit the delete key.
Peter Devlin
Link
This is actually a feature from Graphisoft to you!
I am not sure exactly why they decided to do this, but as I recall it has something to do with dimensioning.
Since my reply is pretty much useless, I am hoping someone from GS can confirm it.
Link.
Stress Co_
Couldn't you just turn the "Hotspot" layer off before rendering (assuming all those hotspots are on that layer)?
marc
Marc Corney, Architect
Red Canoe Architecture, P. A.
Erika Epstein
They happen at doors and windows.
Graphisoft has always told me it was a bug. So they changed their mind?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
marc
The hotspots will all be on the layer of the objects that they are associated with.
I've never seen this happen. Would you PM me and l'll give you an address to which you can send the file. I'd really like to take a look at it. Hot Spots are not supposed to print; are you telling me they are?
woodster
Link
Woody simply generate any elevation with a window in it, then change that section to a Drawing and you will see hotspots turn up. They don't plot - they're just regular hotspots but they turn up!
Link.
