how can I creat continuous rail?
how can I use a continuous rail ? I mean instead of each segment...
to creat a continuose rail that connect perfect in the corners....how?
20 Replies 20
You are going to need to be more explicit.
What kind of rail ? stair rail ? guard rail ? railroad track rail ?
Borrowing from another member of this forum.
You should add a Signature to your Profile
(click the Profile button near the top of this page)
with your ArchiCAD version and operating system
(see mine for an example) for more accurate help in this forum.
Peter Devlin
I working on AC v.11
all I need is to "draw" a rail (my parameters as height,gaps etc that I define) the same as I draw a wall !!!
can I do that ? why does it come with segments? I want it to be continuous !
I am talking about only rail !!! paraphet ! not stairs....
thanx Peter
Dwight
The answer to your question is to investigate "Complex Profile" where any shape can become a wall profile - like handrails.
Dwight Atkinson
Are you trying to draw a parapet wall that is curved in plan and
is not made from a chain of straight segments ?
If so, you can use the wall tool with the curved geometry method.
I am sorry, I obviously don't understand what you want to do.
Peter Devlin
Peter what is unclear? I have a balcony ,alright? I need a paraphet with columns !!! not a wall 110Cm....paraphet made of wood...metal whatsoever...I need to draw the paraphet along the balcony contour continously...
complex profile..I will check this thanx
I found the complex profile comlex to me !!!
any helpwould be appreciated...
Dwight
We discuss "Complex Profile" a lot.
Try to search for previous postings on this forum.
See the Reference guide.
Dwight Atkinson
but it should be soo simple..can`t I make it with "element" : "rail"?
is that complicated?
I found there my rail profile just it makes segment instead to be continuos.
Archicad is not that simple apparently.
screen shots of what your doing might help portray what your trying to ask... i still cant work out the question
