Got a minute? We appreciate your feedback:
Graphisoft Learn survey
how can I creat continuous rail?
how can I use a continuous rail ? I mean instead of each segment...
to creat a continuose rail that connect perfect in the corners....how?
20 REPLIES 20
something like in the pic
Maybe I'm not understanding either, but what is wrong with the standard railing objects.
From image below,
1 - in object tool I searched used the Find Library Parts option...
2 - searched for "rail" and got lots of options.
3 - picked one from the standard library that has lots of variables
4 - you can set sizes, gaps, end cuts etc
Place one on your plan and stretch length to suit, and there is a curved variant too.
thanx !!! that what I was looking for !!!!!!!!!!
damn ! it is only vertical posts !!!
can`t I make it horizontal? why it must be that dificult
pilgonico wrote:
<b>[censored]</b> ! it is only vertical posts !!!
Your photo clearly shows vertical bars, and my image shows an option for horizontal as well (Railing Horizontal 11). Calm down, open your eyes. This is the easy bit.
u can even see the horizontal ones in s2art's screen shot... most of the vertical ones even have a horizontal option with them... just look in the objects parameters. theres dozens of options and variants for each rail
it is not difficult.
choose railing horizontal/ vertical
then you choose the third/ fourth geometry method
then for the linkage between railing, you have to set cutting angel of the railing in the parameter
below is the geometry method u should choose
u can edit the angel in end cuts
u can rotate the object before u start, in the top right corner
linked railing on plan
linked railing on 3d
it is not that difficult in archicad
but the modeling logic is different from what u 've learnt from traditional CAD
