how can i join two lines to be one line
Hello how can i join two lines easily to be one line as shown in the image
Thanks in advance
1 REPLY 1
The image shows to lines with a gap between them.
To make two or more lines be a single polyline, select them all and use the Edit > Reshape > Unify command.
If you want to unify the lines shown with the gap, you have to either stretch (mouse commands) or extend (keyboard and mouse click) one line to touch the other, then you can apply the unify command.
