2009-03-13 11:23 AM
2009-03-23 05:59 PM
Mark wrote:Yeah but only Zones have the ability to efficently deal with Gross and Nett area calculations which was the original question asked by laylool
I use either zones or the fill tool as mentioned in the above.
Fills work great for sub-areas within zones.
Don't forget slab areas and roof areas included in the 'schedules' are another under utilitized feature. Can quickly tally multi-story, multi area buildings.
Mark
2009-03-23 08:28 PM
The Fill Tool can show the area on the plan (check the "Show Area Text" box), and updates automatically as the fill is edited.I actually hadn't noticed you could do that. What would be better is if you could get the Autotext function to pick up the area's of fills with different labels so you could display an area's table in the titleblock that updates automatically as you change the fill.
2009-03-23 08:46 PM
2009-03-23 08:56 PM
2009-03-23 10:21 PM
Arcadia wrote:Yes, use a schedule with the criteria set to Fill and the layer where your area fills reside. This will give you the table. However, I don't think you can place it in a master layout, it will need to go sheet by sheet.
Is there any way of doing this?
2009-03-24 10:41 AM
2021-09-17 11:05 AM
By using zone, can we calculate the area of slab which has to take thickness also, and indicate value in the plan with different zone types
