how to delete cadimage downpipes?
4 REPLIES 4
figured it out. click the pink node and then type "0" into the dimension box
Or just drag away off the end of the roof
if you drag it away at the end of the roof it is still there
Drag it to the end it originated from, which makes the value 0, or type 0 as you figured out.
