how to increase density of leaves of palm trees
As we know we can increase the density of trees of ficus trees available on library of archicad by density % under parameter setting how this applied to palmtree in setting even if there is no way except download ready blocks has this setting please guide me to this block or if it has specific GDL scripting to effect on parameters please tell me how see the image the palm tree is that not much density
David Maudlin
ahmed_hassan:
One simple solution, without getting into GDL scripting, is to simply rotate a copy of the tree on its centerpoint with a slightly smaller height to double the number of branches.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
vistasp
Ahmed, there is a nice palm in the depository. It's in Portuguese but google translate is your friend.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
