how to make an oval dome?
can anyone tell me how to make an oval roof dome? i'v try the dome, but it always becomes a pure dome (circular)..
14 REPLIES 14
Dwight wrote:
Today my advice differs.
Today, create a domed shell, convert to morph and stretch as needed.
Is this further to your arch/dome issue queried elsewhere?
Thanks for your answer, but I didn't get the last question. The reason why I wanted to use a mesh is that I then need to define the shape of the mesh. I cannot do that easily with a morph... moreover I cannot use morphs yet 😕
Dwight
What kind of shape?
Dwight Atkinson
Dwight wrote:
What kind of shape?
generally, when I ave a morph, I don't know how to define its contours. While I can define the shape of a Mesh in 2D, right? I normally do it. Like, I draw a 3D mesh, then switch to 2D, Define Shell Contour.
Also, I can define a hole in a mesh! So, if I draw a 3D mesh, then switch to a section, draw the perimeter of a hole and then select the mesh and apply the hole, I'm done with one of my problems. But can it be done with a Morph? I don't think I can draw holes in morphs freely from a section or from the floor plan, neither can I design its contours, right?
Dwight
If you can't there is always SEO: Solid Element Operation.
Dwight Atkinson
Yeah at the end I created a solid element, substracted it and moved it on an invisible layer to do the trick! Thanks.
