how to make curved roof?
how can I make a roof whitch is round,curved?? something like a half-pipe?
because I have a corridor and at it`s ends the roof is half of a dome and between those halfs of domes I need that "half-pipe" to connect them
I am sure you`ll have trouble understanding...sorry! but if it`s the case I`ll post an image of the structure
7 Replies 7
Dwight
Depending on the version of Archicad you use, you'll either (Archicad9) make arched roof elements using the roof tool - see attached.
Or: make a custom profile in the shape of an arch to be used with a wall. Archicad 10.
There is also a primitive object - Shell 10 - that will do basic arch geometry
Dwight Atkinson
well I used the "Shell 10" way ...and it works great!! thanx a lot!!!
how do you control the number of 'facets' or roof sections that make up the curved roof? by default, i'm getting five segments - i need a smooth barrel vault instead.
Lindsay,
I believe the number of facets in a barrel vault roof
is controlled in the magic wand settings.
Peter Devlin
Thanks Peter.
Yes it was there.
My question - what does the magic wand have to do with arched roofs?
LINZ wrote:
My question - what the hell does the magic wand have to do with arched roofs?
The magic wand settings define the global curve to facet resolution.
ah. magic wand... not just for magic anymore....
