how to save archicad 13 to archicad 11,10
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2011-03-19 10:43 PM
2011-03-19
10:43 PM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-03-20 03:22 AM
2011-03-20
03:22 AM
See this wiki article which lists what every version of ArchiCAD can read and write:
http://www.archicadwiki.com/ArchiCAD%20versions
As you can see, you can only go backwards one step at a time. So, if you really have to go from 13 back to 10, you will need copies of 12 and 11 and will have to save 13 --> 12 --> 11 --> 10.
Do note that your library parts cannot (in general) move backwards, so a 13 project that you try to save back as version 10 will require a lot of work. You'll get the basic tool elements, but probably not any objects (windows/doors/etc)... unless you modeled the project with the AC 10 library all along for whatever reason.
AC 28 USA and earlier • macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-03-20 10:39 AM
2011-03-20
10:39 AM
is that mean we should buy every version of archicad and there is no other programme can convert it or plugins can do this functionalities?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-03-21 12:10 AM
2011-03-21
12:10 AM
You do not have to buy every version the dongle will work with any previous versions.
What I would do is open the AC13 file and substitute its library with the one I want to save down to, verify and repair then start the saving process.
This is about the third question on this topic. If I may ask why do you need to save down to a five year old version of AC?
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
AC28 US/INT -> AC08
another Moderator
