i need help for modeling
i would like to make a roof like picuture
how can i start
and
i woudl like to make librairy
help me pls
45 REPLIES 45
JaredBanks
Mentor
Steve,
All I can say is wow.
Jared Banks, AIA
Shoegnome Architects
Steve wrote:
You can do a very good job of modeling the tiles with the Conoid object. It is very adjustable on the fly in 3d for tilt, thickness, taper, etc...
Crikey! What's the polycount for that roof, Steve?
JaredBanks wrote:
Steve,
Thanks for noticing. The entire roof is modeled with just the one object. Conoid 14.
The swayback ridge means that every row of tile has a different curve, and the roof slopes in two directions directions in some areas since the hips are curved as well.
If I was getting paid for it, I would demonstrate that this kind of roof can be exquisitly modeled with ArchiCAD only and no .gdl scripting.
You just have to be clever.
"Peter Clark
I have no idea. But it can't be that high, it's not slowing me up at all. ?
so it means your secret is objective? to array the conoids one by one to the the roof?
waaw. ii have to try it out ;D
No no. I did not use Objective. This is done only with regular ArchiCAD, no plug-ins or anything like that.
There are some tricks to it. In the Objective illustration, the objects are multiplied vertical to fit a curve. This only takes care of fitting the one curve but the roof is actually curving in two directions at one time in some places.
There is a little secret about how to multiply with vertical displacement along the curve of the roof running the other way. Horizontal, not vertical.
Think of how the tiles will actually be placed. This is the key to modeling everything. Do it exactly how it will be constructed and in the same order.
Doing this is very easy, but very hard to say with words.
