‎2011-01-27
10:18 AM
‎2023-05-23
04:45 PM
Rubia Torres
‎2011-01-27 03:02 PM
‎2011-01-27 06:13 PM
‎2011-01-29 07:28 AM
Erika wrote:thnx alot for answer Erika Epstein
You should save each building as a module file (.mod). Then place each module in the site file. You may have to cut a section to adjust the vertical placement of each module relative to the site.
Once each module is placed, changes to any of the buildings will be reflected in the site model after you update the hotlinks.
There has been a lot of discussion about this topic. You may need to save each story of each building as a separate .mod (module) and adjust this in the section of the site file so they align correctly. Once the modules are placed correctly in plan and vertically, you will not have to do these steps again. When updating the modules each will retain their position.
If this is a one off, then you could save each building as a library part and then place them in the site file as library parts. Not recommended way, but useful to know.
HTH
Steve wrote:thnx alot for answer Steve Jepson
You could save each building as .gsm then place them as objects in site plan.
‎2011-01-29 09:25 AM
