Rakela Raul
inside fence selection + beam tool comments
the 'inside fence selection' selects a 'group of elements' outside the fence but 'overlapg' the fence?, seems that the group should be considered 1 pack and shouldnt be selected cuz not inside...
the 'beam tool' doesnt have the fill option and i wd like to use it (sometimes in lieu of the missing footing tool)
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
8 Replies 8
Is there a question being asked here?
Rakela Raul
no, only a couple of things that calld my attention and could b important for someone else ..thx
I disagree. This is proper behavior to me ... grouping says to select anything in the group, at all times. If you want the behavior that you had hoped for, Rakela, then you need to 'suspend grouping' (alt-g is the default keyboard shortcut).
Grouping needs to be suspended for all kinds of other operations, so this behavior seems consistent and logical IMHO. 😉
TomWaltz
I believe the Marqee tool follow the Arrow Tool settings for "crossing" and "fully inside" when it comes to selection.
Tom Waltz
Rakela Raul
hey, dont bite my head off for that karl...!!
if you are using the 'inside fence' why should i see highlited elements outside the fence??
because they belong to a group of elements, a few of them inside the 'inside fence" selection?? , do u really think it makes sense?
more logical in my personal opinion should be that you see them highlited with the typical id for grouped elements and you shouldnt be able to do anything with them because they are part of others elements somewhere outside the 'inside fence' selection....
and btw, thx for the selection/search tool "wake up click" this past weekend.
TomWaltz
Yes. That's the PURPOSE of grouping. If you select one item, other related items move with it. If you do not want that behavior, you turn on "Suspend Groups."
Tom Waltz
Rakela Raul
ohh ok i didnt know that thx and sorry about it
Rakela Raul
deleted and moved to 'others products'
