interior elev...
i can't understand . I've checked the wc & slab surface setting and it's SUFACE WHITE but the interior elevation is showing ' BRICK' like surface.
Help!!!!
15 Replies 15
i'm using archicad 7 and the objects 70...i'm also experiencing other objects such as the kitchen/oven, microwave are not showing in the elevations but they are showing in the sections!
any patch or do i have to spend another 2k for ac8
This is definitely strange.
I don't remember any such problems in AC7. Do the parts show up in 3D? I wonder if the default 3D pen is one you have set to white. What color is your screen background?
i've seen the objects in 3d and sections and there's not problem...it's just the interior elevations that the objects are not showing...
Are you saying that they elevate correctly with the section tool? If you are using the interior elevation feature (in the tools menu) the problem could be with that. It is an add-on function which doesn't work very well yet. I recommend using the section tool (with vertical and depth limits) to set up interior elevations.
thanks......about the sections. i am noticing that when i delete any sections, the section identification numbers doesn't return to 1. how do i reset the numbers other than manually change in the setting box?
There is no other way.
The numbers will increment from whatever default is manually entered.
