interiors, going inside, going through. I cannot do this
Hi. I have problem. I cannot look through objects (like wall) in 3D. I used mouse scroll wheel for going through model. Now I cannot go inside and work with interiors :S. Maybe someone know how to fix it?
If you wish to walk though you model, select 3D perspective view, not 3D axonometry view. At the bottom of the 3D window there is an button with a silhouette of a person. Hit that button and it will show you splash page with the commands to use to walk through the model, close that and you should be able to use classic WADS (if you're a gamer, you will understand) to navigate or "fly" in your model like you're in a first person perspective video game.
Thanks for trying to help. But it doesn't work. It is still zooming when i go forward. Maybe there is other solution?
Is it possible that perspective view is off although archicad show that it is on?
