just a question...
what archicad version works on powerbook g4, with mac os x 10.4.6?...
thanx a lot...
aenid
4 REPLIES 4
TomWaltz
Almost any version from 8.1 (or even 7) onward will run on the Powerbook it just may not be very fast.
Tom Waltz
ah ok...if i choose to run AC 9 in powerbook g4, what should i do?...is it possible to change my os?...AC 9 requires mac os 10.2 or 10.3...
thanx again...im a new user for both AC and MAC...
aenid79
__archiben
you'll be fine. it means any version from 10.2 or 10.3 onwards . . .
i was running archicad (including AC9) on a powerbook G4 for years (10.1 right through to the latest 10.4). you will need to get as much memory (RAM) as you can though . . .
HTH
~/archiben
b e n f r o s t
tnx so much...ill try it when i get home...
aenid79
