keeping guide lines
Dave Brach
my guide lines disappear after the next operation. How do I keep them on the screen until I want to manually remove them. NOthing under "guide line options"
Dave Brach/architect
AC26 MBP OS Ventura
AMD Radeon Pro 5300M 4 GB
Intel UHD Graphics 630 1536 MB
Gerald Hoffman
Ah yes that would be nice wouldn't it. I have wondered the same thing but just assumed the Graphisoft programmers thought we would only need them for one operation. AFAIK you can't have them stay on the screen but maybe someone out there knows how to achieve this.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 27-5030 USA
2019 MacBook Pro (64GB w/ AMD Radeon Pro 5600M GPU)
They will indeed disappear after the completion of an operation.
There is no way I know of to delay this.
If you need a more permanent solution then you will have to use lines and delete them when not needed or better still put them in a layer you can simply turn off.
Then turn the layer back on if you need them again.
You can set up a few lines at common angles that you can move and duplicate as needed then just turn the layer off.
Dave Brach
wow, I thought for sure I was just missing this in the settings somewhere. This is another area where sketchup is way more user friendly.
AC26 MBP OS Ventura
