library parts fills not obscuring object behind in PlotMaker
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2004-02-11
10:48 PM
ā2023-05-23
05:29 PM
Rubia Torres
I've tried all of the various Fill settings in PlotMaker but those settings did not seem to fix the problem.
I use Fills (Solid Fill, Fill Pen 91, Fill Background 91) to obscure lines and objects when I need them not to show up in Plotmaker. These settings work for Fills but not for Objects.
Can anyone please tell me how to get Symbol Object's fills to obscure objects behind them?
Thank you,
John
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-02-12 04:51 AM
Most people like for the building to show through otherwise they wonder what you are trying to hide with the trees.
However, for you and your desire, open the plant's GDL to see if there is any code in the 2D script for a fill. You need to look simply for the FILL command. If there is no FILL command then no matter how you change the part it will never obsecure the building.
Also check that the library part is foward of any other object. This is the move forward command found under the OPTIONS menu.
Perhaps a screen image of both the AC and PM windows of the elevation in the same picture would help us to help you better.
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-02-12 05:27 AM
We have CC&Rs that are asking to see the relationship of the trees to the structures. We are deliberatly trying to obscure the building with the trees in this view.
Yes, the tree symbols do have fill properties. I am writing to find out why the fills are not working in PlotMaker.
As you sugestted I am posting an image of the trees and house in ArchiCAD.
Thank you,
John
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-02-12 06:50 AM
Try checking your Display Options in PlotMaker.
Specifically: Options>Display Options>Options For Display & Output>Fills: Keep Original Settings.
This way, the fill applied to your tree (which I am assuming is set to pen 91 (white)) will act the same way in PM as it does in AC, and you'll be laughing all the way to the plotter
Good luck.
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-02-12 07:04 AM
I wish it was that easy. Before I posted the first question I tried ALL of PlotMaker's Display Options for fills with no sucess.
I would love to be laughing. Tell me about the weather up there.
Many thanks,
Aloha,
John
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-02-12 03:40 PM
The weather? Well I am working in Casper, Wyoming this week and the weather is 'bitterly cold' - and that's not my description, that's how the local meterologist described it on TV! It was 22 below last night (fahrenheit!). And then there's the wind that just goes straight through you. They said that if you spend more than 10 minutes outside, you are susceptable to frostbite. Frostbite??!!! I'm from Australia - frostbite is what you get if you venture to the South Pole or try to conquer Mount Everest, not something you are 'susceptible' to on the way to work! Jeesh!
I hope it is warmer in Hawaii! If you like, please send a small PLA example of you problem file.
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-02-12 10:05 PM
Thank you Link. Your suggestion to try a new Plotmaker Layout Book with the default settings (New and Reset) put me on the path to the solution.
In the new Layout Book the fills obscured the building in the background just fine. The problem was not in the Display Options but in the Preferences/Miscellaneous setting for Fill Background Color. My problem Layout Book was using this setting at "All Fills Transparent". This setting needs to be set to "Use Fills' Background Color" to obscure the objects in the background. Of course the fills need to be set properly in ArchiCAD for this to work. The Plant Symbols in the 8.1 library do have their fills set properly as they come out of the box.
I should remember to look in Preferences when all else fails as I've had a setting in this menu throw me off before.
My thanks again to you for putting me on to the solution. I'd offer a frosty beverage as my thanks for your help but it sounds like it is a bit chilly up there for a cold one. Let me buy you a drink the next time you are in the neighborhood.
Many thanks,
John
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-02-15 03:52 PM
Glad I could help, even that obscurely. I should have thought of that too.
I'll definitely take you up on the beer - just have to find a reason to be 'in your area'
Take care.
Link.
