We value your input!
line tool
dhnguyen
Where do I go to turn on the option that automatically groups 4 lines in a square when I draw it?
I have two ArchiCAD files, one of them has that option where I draw a square using the line tool and when i select it, all the lines in the square are automatically selected.
In another CAD file, I cannot grab all the lines in the square at once... note that "Suspend Group" is disabled, so I should be able to grab them all.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
mikas
Edit > Grouping > Autogroup
AC25, Rhino6/7+Grasshopper, TwinMotionMac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RX6800XT/W10ProWS
mikas
dhnguyen
Got it, thanks!
DNguyen
ArchiCAD 18- 25
