cremsberg
locating a detail bubble
I have a detail drawing shown in the list of the Project Map. I can’t figure out where on the plan or in Section/Elevations this detail is taken from. The detail drawing does not show any data that would be a clue. Is there a command to locate the detail tool placement that originally created the detail? I have several obsolete details like this and I would like to clean them out of my working file
Claire Remsberg
Remsberg Architecture, P.A.
MacBook Pro, OSX 12.6, ArchiCAD v25 (5010)
4 Replies 4
Laura Yanoviak
Right click on the detail in the Project Map, and there may be an option to "Find Linked Markers..." -- if not, then it's an Independent Detail and not linked to anything!
TomWaltz
It's possible that it's an independent detail and does not have a source. Which icon is next to the Detail?
Tom Waltz
Stress Co_
NOTE: If the detail's layer is turned off .... this option will not appear. You may want to turn all layers on to check.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Link
You may want to check out the post here.
Link.
