manipulating IE Markers once they are placed.
It seems that the IE Marker is always placed in the center of the IE Marker Boundry selected... Does anyone know if there is a way to move the marker without changing the elevation views? Or to manually select where the marker is positioned within the boundary? I currently do not have zones set up - Would this make a difference?
Any ideas are appreciated!!
Yah there is a hotspot in the center of the marker. click it and select the move marker icon.
So Simple! Thank You!
