mapping and modeling part 2
here is what happened
Djordje
How did you map it? Is it a wall or an object?
Which ArchiCAD?
If a wall and the ArchiCAD older than 8.0, use Special Menu to Set Origin and Set Position. If 8.x, use Edit/Align texture.
Also, no point in setting two different topics for the same thread. ou should have replied to your original message in order to keep it in the same topic.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
