max rendering window size?
Achille Pavlidis
from what i understand there is a limit in the resulting size of the rendering image size depending on the resolution. I was trying to make a 70x50cm image at 150dpi, but i found that with this resolution, i'm limited to a width of 68.55cm. Did i miss something or is there actualy a limit???
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
1 REPLY 1
Achille wrote:
from what i understand there is a limit in the resulting size of the rendering image ...
The total pixel maximum for any image is 4048 x 4048
