mesh gravity tool
Llian
i don't have the manual and surprisingly the help doesn't quite provide help other than pointing to where the tools really are. anyways, attached is mesh tool where is the gravity tool so the spot elevations are showing the grade elevations?
my other problem is i can't delete the spot elevations which i have placed on the bottom left corner which are all showing as +0.00. When i clicked on the symbol and hit delete, the whole mesh got deleted as well.
patiently learning!
Lilian Seow
LEED AP | cSBA | CAPM | PMP
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
13 REPLIES 13
Llian
the itg doesn't come with the reference guide...this is education version for limited time probably doesn't have the priviledge of the guide!
Lilian Seow
Llian
ok got the level elevations to fractional decimal how do i
1. adjust the levels in the section views [other than story options] ?
2. adjust the test - the text seems to overlap ?
sound like there is a manual other than the iTG and i suppose that comes with the paid versions....doesn't graphisoft make it attractive enough to have it available for learners..this is discouraging to learn the software!
Lilian Seow
Sorry about that Llian.
I did not know that.
lec
Erich
Llian,
Not to belabor the point, but this is what you should be seeing (this screen shot is 12 as I do not have 13). Unless GS has changed their policies the ITG and demo versions are complete and only limited in print save and similar functions (once the ITG goes to demo).
I am not certain what you are asking in your other questions. Your screen shot is too small to see any text. If you are just looking to move your object up or down you can just select it and drag (command D) into position.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
