ā2009-02-17
07:30 AM
ā2023-05-25
05:09 PM
Rubia Torres
ā2009-02-17 08:02 AM
GeNOS wrote:Set the top contours for the mesh and give it a thickness of at least 100mm below your lowest contour level..
I know its been asked and answered before, but I couldnāt find any of the threads..
But how do I get a mesh to have a uniform thickness of say 100mm or what ever.. instead of the bottom having a set height and it gets thicker the higher the mesh goes..
for say an uneven driveway/path etc...
thank you
ā2009-02-17 02:00 PM
ā2009-02-17 03:12 PM
laszlonagy wrote:Or try the Mesh 3D V2 in the Object depository
The other option is to use the Mesh To Roof Goodie to achieve this effect.
Click the Goodies link in the Help menu to go to the download web page for the Goodie.
ā2009-02-18 07:49 AM
ā2009-02-18 08:33 AM
GeNOS wrote:Make sure you have the mesh selected first.
i downloaded the mesh to roof add on and followed the instructions on installing it. only problem is when i go to use it, its greyed out and i cant select it????
ā2009-02-19 12:09 AM
ā2009-02-19 12:25 AM
