2006-07-24 11:36 PM
2006-07-24 11:46 PM
2006-07-24 11:55 PM
Benjamin wrote:merge. there are two ways, and depending on the extent of your template you should consider both . . .
Anyone knows how to do this?
I have a preliminary completed project in AC9 and I want to convert it to
AC10. I have a AC10 Template that already has all the layout setups.
So I want the contents of the AC9 Model file but not the layout files.
When I tried to open the AC9 file into my AC10 template file, all the AC10 layout setups are gone. Thanks.
2006-07-25 12:21 AM
2006-07-25 07:56 PM
2006-07-25 10:47 PM
Benjamin wrote:no. it's File>File Special>Merge...
Is "merge" = external contents>Place external drawing? Since there is no merge command in AC10.
Thanks
Jay wrote:i just merged a 9 file into my current 10 file - which is using some of the same materials as the 9 file, appended using 'attribute manage' - and the material name stays the same (i.e. archicad
When merging the AC 9 file into this new AC10 Template how are the materials and fills with the same names, but different ID's assigned?
2006-07-25 11:13 PM
