mitre beams (profiles) in elevation
Tom Krowka
See the attached pic. Is the only way to trim these beams to a nice mitred intersection to use a roof and seo to the intersection? I thought maybe the trim or intersection tools might work. I tried SEO to each other, but that did not work.
The trim configurations are actually a complex profile.
Thanks.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
6 REPLIES 6
Erika Epstein
SEO is the right way to go, but try using the roof overhang above them as the operator and subtract with upwards extrusion.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Thanks.
3D Window
Floor Plan Window...
Trim to Roof...
Ralph Wessel
Mentor
Thanks.
If this isn't a one-off problem, you might want to look at OBJECTiVE. You can cut up profiles with the a split tool (as you were hoping to do) without messing around with SEOs and cutting planes: http://www.encina.co.uk/objective.html
Take a look at some of the example movies to see the tools and objects in use.
Ralph Wessel BArch
Active Thread Ltd
Rakela Raul
I have been checking on Objective by/from Ralph W, what an impressive tool !!
and not 'possessive sick' as the typ addon
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
