Just another comment on this, depending upon what Danivici really wanted...
The illustration that Peter gives will provide the cut shown in the original elevation, but this may not be the cut desired for construction.
Given the curvy cut of a curved surface, and assuming the construction materials are metallic skins, I would think that the desired cut would be perpendicular to the curve tangent at all times, giving a 90 degree edge at all cut surfaces. This would allow pieces of rolled material of a fixed width to be attached (welded?) for the edge.
Unfortunately, we cannot model this in ArchiCAD. We can take a profile similar to Peter's and apply it to a column or beam and anchor the profile at the origin of the circle defining the curved wall to approximate it. But, there will only be a true 90 degree cut for that one anchored point - all other parts of the cutting curve will be at other angles.
Dwight's tips on combining profiles with profiled cutters are really very helpful though!
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
